Allen Bradley micro 820 no LED,s lit
GazzTee
May 2023
Arbroath
This unit was removed from one project where it had perfomed nicely. Wired into simulator and we have no signs of life no LED,s lit power supplies checked is there a reset or some obvious checks we should cover
Remove everything but the power, just a wag but if you have a short it maybe dragging down the power, so discounted everything but the power and see if the it powers up if it does then your issue is in your simulator
Have powered the unit up withou any inputs or outputs still no indication of life yet moments prior to changing to another project it was operating ok. No signs of poor connections or faulty components.
Hello Everyone, Hope you all are doing well. I am new to the PLC and communication protocols used in PLC. I am currently stuck with Allen...
47
13,867
Hi all, I have problem that I could do with some help with: I have a setup consisting of an Allen Bradley Micro 820 controller, Panelview 800 and...
3,061
I have an allen Bradley micro running a fan in an industrial paint mixing facility. The input fuse is 3a. The system will run fine for a bit and...
1,988
Found a couple of old unused Micro 810s with lcd displays in the miscellaneous section. Don't ever use ccw or indeed any Allen Bradley, but...
4,166
Hi guys, I need to add 2 x 1769-IF4 and 1 x 1769 OW16 output card into an existing Micro 1400 Series A PLC. It has already has 3 expansion...
2,840
