2080-MOT-HSC Programming With the HSCE FB
BMartens15
Sep 2020
Manitoba
Hello,
So I have a Micro850 PLC with a 2080-MOT-HSC Plug-In module, and i'll be using this for an encoder.
I think it was version 11 in CCW that they introduced the HSCE bit for the plugin module.
I'm trying to use it currently but there's not alot of information online. Currently, I keep getting ErrorID 13 on the HSCE function block. I have no idea what that is.
Is there a table that I can identify these error codes? Or a resource to help program the HSCE?
Good Morning BMartens15.
I suggest you try using the HSC_Mode0 Function Block instead. If you need some particular functionality from the HSCE block your already using, then fine.
I have always found the HSC_Mode0 UDFB much easier to deal with than the HSCE. Easy to Start, Stop and Clear.
I can send you a bit of Logic that Iv used it in but the download is well documented if you download the UDFB from AB.
Just a thought, as I see your post wasn't a hit. Maybe few else uses the HSCE instruction either, somebody told me about it and Iv never had to look at the HSCE again!
I'll have to look at the HSCE_MODE0 UDFB. For now, I was able to make the HSCE work. I had to change some numbers in the HSCE_CNFG.
But for anyone using the 2080-MOT-HSC, it's incredibly difficult to troubleshoot because of the lack of information.
Good day, I have a micro 850 with a 2080-MOT-HSC that is being fed by two flowmeters, Schneider Electric using IMT31's as converters. They are...
464
I'm trying to set up a ring counter - one that transitions from 3599 to 0 (and 0 to 3599 in the reverse direction). My counter insists on...
364
Hello everyone. I'm having some error on the pulses read by the HSC card. I'm using the 2080_MOT-HSC as a pulse counter; in the CCW in using...
631
MICRO 820 PLC - 2080 MOT HSC - Jencoder J-15S-SL Above plc, add on module and encoder are using to configure one paper cutting machine...The...
3,872
I was looking at the HSC function block in connected components and was stumped by the documentation on how to address the input for the HscID in...
3,917
