230v Estop
PE
Well, Terry ole pardner, I is a P.E. (Professional Engineer) and that designation covers a multitude of sins. Like so much else in the US of A, engineering registration is a state goevernment function, but most states nowadays use the standard national P.E. exam and generally folow the same procedures. When I took my P.E. test it didn't differentiate between electrical, mechanical, and civil engineering licenses, apparently figgerin' if ya was smart enough to pass the test ya oughta know what you was qualified t' engineer. Most states now do define the area of licensing. Some states, notably California, have stricter requirements. Most other states (again California is a notable exception - I believes due to siesmic requirements) will grant recoprocity to licenses from other jurisdictions.
Ya don't need no engineering degree t' git a PE license, but it helps. You kin acshully still git a PE without taking the test, but it is tough to git "grandfathered" in nowadays.
Hi, I have 5 Parker IP66 VFDs, 3pcs 400V and 2pcs 230V. Two of them are located on a filtrating machine and three of them are located on a...
2,003
Hi everyone i know this can be done using a capacitor in paralel. My question is if there is any limit in the power of the motor to do this. The...
2,025
Hello all, Who have links for documentation,- how to connect Allen Bradley 3 phases VFD PF753 in test purposes using only 230V. Approximate...
1,559
Very simple question, can Power supply module PS 60W120/230V AC/DC(6ES7507-0RA00-0AB0) work on 100 V AC voltage? Basically can this power supply...
1,426
Folks, Where I work we have a 230V 1 phase supply and Motor is 3 phase 230V. We connect an ac single phase powerflex 70 and let it produce 3...
6,098
