2706-P22R led display Programming by PC
breast69au
Sep 2013
Australia
I have just bought one of these and am just needing advice as to what type of cable is required to program this with the computer.
I made up the 2706-NC13, just went pin for pin on each plug so 1 went to 1, 2 to 2 and so on and also grounded the cable to the connector and the computer is not talking to the display with this cable. Should mention the program I am using is the Inview Messaging software and its an old P3 laptop that I now the serial port works as I use it on another programmer.
My question is the 2706-NC13 the right cable to us or should I be using the 2706-PCABLE1 and if the 2706-PCABLE1 is the cable I should be using does anybody have a wiring diagram for it???
Please Help
there is a lot of info here
what PLC are you connecting it to and are you using rs232 or 485
Welcome to the site by the way
I am using rs232, if I just want to use the led display just to display a simple message do I need to use a plc??? Am I not able to just program my message to the display???
now your asking - honestly I dont Know
the last one of those I used was a Uticor version.
you could program the display - But you need something to tell it which message to display - hence the need of a PLC
give NHP a ring - there are some very good people in Melbourne
I am using a ControlLogix processor and rslinx. How on earth can I sync my display time and my system time automatically? I sure could use the...
2,116
hi, i trying to trigger message from control logix 5000 to inview over ethernet. i already established comm but i need and idea to trigger...
2,372
Greetings everyone ! I'd like to use the TSX57453A by Schneider to set the messages in the Inview Display I have used the 2706-PCABLE1 to...
3,005
Does anyone know the pinouts for an AB 2706-PCABLE1 programming cable for Inview displays? I need to build one. It's DB-9 female at one end...
2,284
I am trying to set up an InView display (2706-P42R-SC) with an ethernet communications adapter (2706-PENETM). I was able to connect to the...
3,784
