2711p-t10c21d8s // e-mail sending
Max4507
Feb 2016
Québec
35
Hi All,
I am trying to send e-mail from this HMI. I have it done working with the simulation, but when trying from the HMI it reply : Internal socket error : Error code 9.
Anyone can give me a hint?
Best regards,
Whatever server you have configured for the email to send through needs to be accessible to the PanelView.
Rarely are these on the same network as your PLC kit. It likely works through simulation because your PC can see the server.
So, check to see if the PV+ can talk to the email server. If the PV+ doesn't have a gateway address and the 2 systems aren't on the same subnet, it will require some work!
Oh god.. almost forgot about this post!!
We finally solved it, but do not understand how! We tried another e-mail server then it worked just fine.
Put back the original e-mail server info, then work fine..... We had programmed an auto-fill for the e-mail parameters (which were the parameters not functioning).
Used that auto-fill function, still working just good.
Sometime life's is just like that!
Thanks every one!!
Best regards,
We broke the glass on the new PanelView Plus 7 .... 2 months after the install. Our vendor stated that we cannot buy the repair parts...(Touch...
209
Every time I power this unit up it loses its IP address and goes to DHCP . When I goto the config the IP address is 0.0.0.0
737
I have a few 2711P-RP series Modules for the PanelView 1000. I purchased them because the price on the new TD series is criminal. The have no...
1,031
Hello All, Does anyone have a problem with the new style HMI 2711P and gray brackets that break while installing? Replacement brackets AB...
654
Hi all ran into something that I have not seen before. I have a 2711P-T12W PanelView. Just flashed to Ver. 12, saved the runtime file VER 12 load...
1,411
