3-Phase Motor Connectors/Receptacles?
JeremyM
May 2014
Dallas, Texas
1,233
Hi all,
My current personal project is to build out a portable test rig in a Pelican case. It'll contain a PLC, some I/O, comms/gateways, and a pair of 120VAC PowerFlex 525 VFDs (0.5 HP). One major goal is to reduce as much as possible case penetrations (input power and some field outputs are exceptions).
I've even found adhesive mounting nuts to secure the sub-panel without drilling:
https://www.mcmaster.com/nuts/nut-type~adhesive-mount/
Some lightweight, rugged power input cabling has been located at Neutrik:
https://www.neutrik.com/en/neutrik/products/powercon
The Neutriks are my favorite so far since they support gaskets/covers and are recessed. I've search around without luck at other places (including Meltric) for similar connectors/receptacles that would support 3-phase motor hookups.
https://meltric.com/products
Has anyone found something like this before?
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
539
Hi PLCs.net! I'm working on a multi-motor system, most motors are single phase, driven by servo drives. I wanted to check what kind of motor...
1,534
Any panel I've built with contactors and overloads has been 3 phase. I'm now quoting on one with some small single-phase loads. Definition of...
24
5,674
Hello everyone, I ran into this 230 single phase two speed motor with two capacitors and a relay (see picture) and have a few questions: The...
1,405
Good Morning , I should know this , but will a 3 Phase overload trip if a 3 Phase motor runs single phase for a long period of time ...
2,196
