Hello everybody.
I have got a tanker where we have a 313C running the safety system on the propulsion engine. The engine has a pick up which is a proximity switch wired to the counter input on the plc. It is reading the rpm of the engine.
sometimes it is showing strange values which can not be correct. When I check the module information buffer, I got the meassage which is in the attached document.
Has anybody seen that message before:
"Modue problem or maintenance necessary", I am thinking that might make problems for the rpm reading.
Thanks for any answer...
brg
Andreas
brg
Andreas
