Siemens cpu 313c
gandr
Dec 2009
GREECE
37
Hello everybody
i have a siemens cpu 313c and when i tern power on all leds
at front of cpu stay for a sort time on and after all leds go
off exept SF blinking
has anybody any idea where problem is ??
thanks in advance
SF: systemfault (hardware or software)
Read out the diagnotics:
Simatic manager > PLC > Diagnostic-Settings
Did you plug in the MMC-card?
In my experience, that's one fo the few ways to get a SF directly on start-up.
Even without HWConfig and program, but with MMC, the PLC will shortly try to go into run, then go into stop. (Green LED flashing, then orange LED goes on)
Thanks my friends for your response.
-was imposible to saw at diagnostic because there was no conection with pc.
-problem wasn t with MMC because all leds was off exept SF blinking.
finaly i found a new cpu and exchange it and machine is running.CPU was crashed !!!!
thanks
Hello; I need help downloading a program to a Siemens CPU 313C. The program was uploaded from a 314IFM. I modified the HW Configuration by...
13,672
Dear all friends i have a siemens plc CPU 313C with integrated analog inputs one of them can be directly given to a resistance ( as per mannual...
4,472
Hey when I turn on my Siemens PLC CPU 216-2 after runing 10 minute it's stop and showing SF indication after I turn off and some time later turn...
126
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
113
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
752
