315F PN to 315 PN Communication- Master/Slave
PLC
Sep 2002
NC
311
I am putting together a system and I want to pass data back and forth (really just I's and Q's). With profibus I typically make one a master and the other a slave. I then network the two stations together under configured stations in the HW catalog. Easy
I dont see this with profinet. Am I missing something?
I thought about i-map and CBA but I would rather use the above master-slave
Ideas?
Unfortunately, PN CPUs can only be Profinet IO Controllers, not IO Devices.
So something similar to DP master-slave is not possible.
You could setup either an S7 connection, and send the data via PUT/GET blocks.
Or you could use the TCON/TSEND/TRCV/TDISCON blocks to send via UDP, TCP or ISo_On_TCP connections.
And then there is iMap too as you suggest.
You can also use FB12 (Bsend) and FB13 (Brcv) to send data back and forth, I've just done exactly that to pass a limited amount of data between two PLC's. I'm sure there is a "How To" and a downloadable example on the Siemens web site but I can't seem to find it. Just make sure you get the correct versions of FB12 and FB13 or it just doesn't work... as I discovered.
Nick
Hey, my problem is : is there a possibility to establish profisafe connection between S7-315f-PN and Simotion D435-2-PN while using 7 drives/axes...
1,873
Hey folks, It's my first time doing any STEP7 programming and I'm working on a safety program in this control system. I think I understand the...
2,536
Hello, I'm using a 315F-2 dp/PN fail safe CPU. I also have an extension rack with a IM-365 module. Can someone tell me if it is allowed to use a...
3,977
Hi All, I am working on a project where I am integrating two different PLCs on a single network. I want to know how can I access I/O points of...
3,483
Hi This is the first time i try to have OP communication over profibus but so far i havnent been able to get it working. What steps are...
5,624
