3Φ induction AC motor with VFD.
... Now stopping will need a special VFD with a braking circuit. The motor will get hot as there is current flowing but motor is not running its normal rpm. so extra cooling will be ...
Unless the VFD is set to just allow the motor to coast to a stop, which on a gear reduced conveyor drive is likely the case. If it were started ATL, there would not likely be a brake either.
Braking and bottles don't go together well in my exerience. Don't ask how I know... :sick:
If acceleration is not a big deal then it sounds like a good application for a clutch. Lot's of energy wasted starting and stopping this motor. Check out warnerelectric.com
Clutch/Break....
This is used in one of the filling machine in my previous work. Works pretty good and stop position is very repeatable considering the position tolerance is +/-2mm.
From my experience with the machine I think this is your best option.
Is there any issue with running a VFD-controlled 3-phase induction motor in torque control mode in the braking region continuously (back-driven by...
4,119
Hello everyone! I'm new here and this will be my first post so hopefully I can get some help, I'm having a hard time wrapping my head making some...
4,866
Why it is said Maximum torque of induction motor is inversely proportional to frequency square ? Maximum torque formula for induction motor is...
4,591
I have an auger powered by an induction motor under flux vector torque control driven by a PowerFlex755. According to my log, the command velocity...
5,129
As you know there are three region for induction motor's operating. What I'd like to ask if motor is regenerating energy during plugging which...
1,564
