4-20 Loop 2 Wire vs 3 Wire
thanks for the reply.. i'm using Yokogawa Singal Condition Card (GS 33M50H85-40E) Model EA1.. it uses 2 wire system as in attachment.. my gas detector uses 3 wire system which is 24V,GND and 4-20mA signal.. if can't view the attached images, the images can be found at http://www.imagebam.com/image/801eef211082433 and http://www.imagebam.com/image/289494211082630.. thanks..
801eef211082433
289494211082630
I'm just guessing here. I'm not familiar with Yokogawa and that documentation is just about as ambiguous as you can get. It appears to me that the card can supply 24 VDC from A to B and then there's a 250ohm resistsor connected from B to C so that all it's really doing is converting the signal to 1-5VDC. I can't tell for sure. My first attempt would be to connect it this way:
DCS Transmitter
A --- 24V
B --- GND
C --- 4-20mA
If that doesn't work, I'd go with a separate power supply. Connect the (+) and (-) from the power supply to 24V and GND on the transmitter. Also connect the (-) from the power supply to B on the DCS and then connect 4-20mA from the transmitter to C on the DCS. It'll end up looking exactly like the middle diagram on one of the earlier posts.
I was wondering if anyone had an success finding a Database driven managment program that can save&print all the following...
2,266
I'm probably going to be called stupid for asking this. I have only ever used 2 wire sensors. we would connect one wire to 24 dc+ and the return...
41
7,194
Hello, I've a question regarding wiring analog inputs (4-20mA) to a compact-logix 1769-IF8 module. The PLC and module exist already and are wired...
6,804
Hi, I'm quite new to Rockwell PLC and currently trying to implement the following if Sw1 then for i:=1 to 20 by 1 do xEnable := 1...
369
Hi all, I'm connecting several 4-20mA sensors together in parallel (only one shown below) The enclosure is ABS plastic with metal backplate DAQ...
274
