4-20ma loops with multiple supply's on different inputs can you the commons together
Vaughan91
Jan 2024
Cairns
Hello this is my first post. Looking forward to being more involved in this community to learn and hopefully help others.
Any help or guidance would be appreciated.
I am building a pump station controller board. (Below photo has more details in the link.)
The board has
A kingfisher plc with IO-3 model card
A schnieder VSD/VFD
1x tank level sensor
There is a 4-20ma speed reference signal coming from the plc to the vsd.
There needs to be a 4-20ma motor current signal coming from vsd to plc.
There needs to be a 4-20ma tank level signal coming to the plc.
I'm a bit concerned if I have a external power supply supplying the power for the level sensor. Is it possible to share the same common ?
I did read in the kingfisher plc manual not to have multiple power sources onto he digital input side.
I'm.a bit lost.
To help explain, Please see link to my onedrive shared photo for wiring diagram
https://gitteljed-my.sharepoint.com...pMgTgJk_9oTA0B1ZqA-Z1XuKT4DtpMNCz-dQ?e=WWVL5c
EWmuIznrsOpMgTgJk_9oTA0B1ZqA-Z1XuKT4DtpMNCz-dQ
Can you add a link to the Kingfisher PLC. Unfortunately Kingfisher PLC is Kingfisher Public Limited Company here in the UK so a web search finding a Programmable Logic Controller made by a company called Kingfisher is problematic :)
Honestly I had a moment of confusion thinking that Screwfix and B&Q had suddenly branched out into automation!
Those are general DIY / trade suppliers for anybody non-UK.
There should be no problem if all these power supplies are isolated and all the commons are joined at a single point, for example in the input/output module.
You never have to add another cable that joins those common ones at other connection points.
There should be no common loops.
Hi, I'm a bit confused over a 4-20ma loop problem I've just been working on and wondered whether anyone out there could help me understand the...
3,811
Little confused! in a 4-20ma current loop where is the current that is consumed by the electronics in the sensor? I assume the process adjusts the...
3,620
Hi all, I'm connecting several 4-20mA sensors together in parallel (only one shown below) The enclosure is ABS plastic with metal backplate DAQ...
275
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
277
What's your go to 4-20ma isolator. I've got some 4 wire 4-20ma from several flow meters and scales that I would like to isolate before it gets to...
1,696
