4 pumps help
papabol_24
Sep 2018
Dammam
Hello
Please help on how to aproach and or ideas to achieve my PLC task. What i have is,
Equipment:
Omron C1000H
CX programmer
4 pumps with aux contact for run indication, with Hand, Auto, Off posittions at the motor controller.
6 level switches/Float switches
Task:
The main task would be basic, lowest Lvl switch will trip all pumps, a pump will run for each water levels, and the Highest Lvl switch will turn on High lvl indicator light.
(Somehow I managed to make a ladder for the basic task.)
Project File and PDF's attached.
I would like to ask for ideas how to make the program intelligent for:
pump fail over
pump lead lag sequencing
My boss wants to add pump operation sequence:
Day1=P1 P2 P3 P4
Day2=P2 P3 P4 P1
Day3=P3 P4 P1 P2
Day4=P4 P1 P2 P3
Can this be achieved with basic NO/NC ladder programming? or i need to learn advanced PLC functions?
Thanks in advance for your time.
So I am working on a system where I need to change the priority running order of 4 vacuum pumps based 1. On demand 2. based on total run time. I...
3,288
dear all.. i am designing the Sea Water Intake pump which the 4 pumps will be operated parallel, and 1 pump will be as stand by pump The pump data...
161
Hello Guys, I have tried the programming but can't twist my mind to make it work correctly. I'm using S71200 and TIA Portal. My system has...
207
I have been reading everything I can find on the P_LLS the last 2 days but I am still having trouble understanding how the P_LLS swaps beyond 2...
583
Hi, I started off my career in PLC programming doing water/wastewater on AB around 20 years ago, but then moved overseas a few years later and...
57
12,110
