4 wire proximity sensor to plc input
jeii
Mar 2011
Qld
Hi. I'm trying to teach myself PLC's on a mitsubishi FX2N-16MR.
I have connected a 4 wire PNP proximity sensor as NO to my plc but it is not switching the output.
The indicator on the sensor shows that its working when it detects and i have connected the NO wire to my input and the NC wire to my 0V as per a wiring diagram i have.
My program simply has 1 NC input and 1 NO input connected to a respective output.
I feel that maybe i have not specified something in GX developer?
I am using a CQ35-25NPP-KC1 sensor.
Thankyou for your help, please excuse my naivety.
I would not attach the white wire to 0V. While sometimes the white wire is not used, it can be used as a NC output, or sometimes 0-10V or 4-20ma output, etc. Keep the wire taped off and not terminated on any terminal. What happens if you manually switch voltage to the input (using a jumper wire from 24V)?
Thanks for the response guys.
I have tried with the NC wire removed, and manualy switching on the input did not work either.
Also, i can see when in monitor mode that the X1 input is not being activated.
It doesnt.
Is there anything else i need to do to associate the sensor with the ladder program in Gx Developer?
You shouldn't. And I believe the PLC Input indicator should turn on regardless of whether or not it's addressed in the PLC program.
Do you have access to a voltmeter? Can you make sure that 24V is being supplied to the Input terminal?
Your picture shows the RUN indicator on the PLC is off. Is that just because the PLC is powered down when you took the picture?
Thanks for your help guys, i should of realised this. Hopefully i will have a more complex problem next time..
These are not used very often I know. I do not have a PLC on this piece of equipemnt that I am attempting to install a monitoring/alarm circuit...
4,783
Hi , I have a 2 wire prox in a 24v dc circuit feeding the input to a plc The prox monitors a lever on a conveyor that moves if the contents...
3,718
Hi all I did a quick search and couldn't find this specifically. I always buy 3 wire 24vdc proximity's and wire them (fused terminal) direct to my...
4,679
How do i connect a two wire and three wire proximity sensors in series with the plc input
4,996
Hello all, While not being a newbie to the instrumentation field, I am not a frequent user of 2-wire proxximity switches. What I want to know is...
7,431
