5/03 & RS232
Your question is a little unclear. But if what you are trying to do is connect to your SLC5/03 thru its serial port using RSLinx for programming. Then a simple null-modem cable is all you need.
See PDF for AB's verison of this. ( all you need is pins 2 and 3 crossed and 5 pin connected). Go to Radio shack and get a null-modem cable 9-9 pin. Or make it yourself.
But with Factory Default Settings of the Port it won't work. First you have to go Online with DH485 and modify the Port settings.
Klaus,
The SLC5/03 has two ports Channel 1 is DH485, Channel 0 is DF1 (RS232).
Below is the factory default for channel 0, which is the port the OP was asking about
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
105
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
250
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
739
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,574
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
393
