5/05 & rs 232 coms (null modem) problem
stuman
Feb 2008
Benalla
37
I have a new L551 that I want to supply an IP address to, so I follow the instructions in the 'ethernet SLC500 processors, quick start for experienced users' guide, and it does not work. I am using a straight null modem cable, 3 wires: pins 5-5 and pins 2 to 3 are crossed. It says that I need the 1747-CP3 cable, but the question is, will the null modem cable work?
I have done it on comm 1 autoconfig, on 2 different computers XP and Win200, it cannot make a connection. When I turn the CPU on, the fault light flashes on, so does the ethernet ligt and then no lights are on, I take it that is normal?
Is there any other way, apart from boottp, of assigning an IP address? what is the IP address by defualt if I reset it and it cannot find a boottp server? I dont know how to use bootp, hence I am trying to stay away from it.
Any help would be great.
Stu
I have a piece of equipment that is operated by a PanelView Plus 600 HMI touch screen via RS232 into a Micrologix 1500 PLC. I am trying to...
152
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
105
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
250
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
739
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,574
