5 pumps will be operate with rotation
tulip
Oct 2005
ist
236
Hi everyone, i am hoping someone my be able to help me.I am using S7-300 PLC and I will be control 5 pumps with rotation.Pumps will be operate according to plc's hour.In this way all of pumps have got same operating times.Is there anybody that has experience?
Try searching previous messages in this forum using the search facility. There have been many extended discussion on this topic, some with 3 pumps, some with 4, some with 5, 6 .... n. I have just tried searching using the keywords 'pump rotation' and found several threads. Some of the posts also deal with the issue of whether to equalise pump/motor wear at all. Equalised wear means that they all fail or wear out at the same time. Can you or the process afford for that to happen?
Regards
Ken
Why do that?
I have been asked to rotate pumps through a sequence in the past. The idea was to even out wear on all pumps. Why would you want all your pumps to fail around the same time?
The only time pump sequencing makes sense is if you're starting them DOL, then you minimize starts per hour on a particular pump. Nobody has ever convinced me with sound engineering pricnciples that one should start a softstart or VFD based pump array and rotate their use.
Anyone?
Greg
Depends on the application. Pumps are rotated in sewage pumping stations all the time and pump wear is not the issue. Having pipes clog due to infrequent use is the important factor since each pump usually has a vertical riser where solids can settle. All it can take is a couple of weeks and there could be enough weight on top of a check valve to prevent it from opening.
dear all.. i am designing the Sea Water Intake pump which the 4 pumps will be operated parallel, and 1 pump will be as stand by pump The pump data...
167
Hello Guys, I have tried the programming but can't twist my mind to make it work correctly. I'm using S71200 and TIA Portal. My system has...
211
I have been reading everything I can find on the P_LLS the last 2 days but I am still having trouble understanding how the P_LLS swaps beyond 2...
585
Hi, I started off my career in PLC programming doing water/wastewater on AB around 20 years ago, but then moved overseas a few years later and...
57
12,161
Good morning everybody, I hope you are very well. I share with you the information of the PLC LOGO! Siemens and expansions that we have...
1,100
