Whatever you do, when you run the command line Uninstaller, don't select all. It will happily Uninstall every AOP you've ever installed. Don't ask me how I know. Thank goodness for VM backups. The 4/10/24 update was generated from my experience.
I don't have a pony in this show as I never had any issues. But be mindful of specific notes.
I've done a lot of work in the past helping manufactures get their **** straight with regards to published documentation, how this actually works in the real world, what is wrong with their published info... It goes on...
In the end, I needed to make this work, so I had to do it with their crappy info and figure it out on my own.
As a courtesy, I would fill them in with specifics. I have no clue if manuals were updated.
It was fun digging into and solving the issues, but I really don't want to do that anymore.
Turns out my issue isn't this particular one. After working with someone else, the actual issue was that I was trying to use the 5069-AENT with an L7 control-logix controller. It appears it only works with 5069 CPUs and L8 control-logix controllers.
The product download and compatibility on Rockwells website would have told you the compatibilities. Always check there when designing or modifying a system.
