milmat1
I have several 5069-AENTR adapters in a system. All of the IO is 24VDC.
Can I use the same power supply (24VDC) for both SA and MOD power into the 5069-AENTR module, when all the IO etc is 24VDC ?
The diagram shows using separate power, however I think this is because you can use an FPD to separate the AC IO if using 120VAC inputs etc.
