5069-Serial module connected to Sato S84EX Printer
tdavid1
Feb 2022
St. Louis
I have a new L306 CompactLogix running V33 with a 5069-Serial module in order to send data through RS-232 to a Sato S84EX printer. I'm unable to get the data to the printer, no jobs are showing up in the print queue.
We know the data gets sent - we tested it connected from Channel 0 to Channel 1 and saw receive data.
I tried Generic ASCII as well as DF1 point to point with no luck.
That module just sends out raw ASCII, is that what your printer is expecting? Have you double checked all the serial settings (baud rate etc)? When working with a new serial device, I usually use a software like RealTerm to figure out how to talk to it from my computer before programming the PLC. It's a lot easier to try different settings and you can see the responses from the device. That way I can figure out what and how to set up the comms on the PLC.
There has been a few posts recently where the 5069-SERIAL module was the topic or at least part of the topic and in those conversations some...
5,279
Does any one have a copy or a source for the v2.012 AOP for the 5069-Serial. If I go to the product compatibility and download center for...
1,437
Hello friends. Old PLC: SLC 5/05 1747-L552 connected to a Dataradio T96SR radio. New migrated PLC: 5069-L330ER with a 5069-SERIAL module. FW...
3,162
I am starting up a new RTU using a L306ER with a 5069 -serial to a Serial radio using DF1 Radio Modem Protocol. I only used it for reading to get...
1,455
Hi all! I'm using a 5069-SERIAL card for the first time, though I have plenty of experience with serial on other AB platforms. I'm running into...
3,819
