512 kb mmc problem
Feb 2010
egypt
dear sir ,
i formatted the 512kb s7mmc ,and i want to recover it
1-could you pls send me the "512kb.s7img" of the mmc.
i had downloaded it from the site but it does not work with the software "s7img.wr" as its extension was "512.img"
thanks a lot
2-is an image of 64kb mmc compatible with 512kb mmc?
thanks a lot
Hello I am currenlty facing a problem on cpu load with using Technological Objects (TO) with a ET200S CPU 1512F. i have two axis drives S210 on...
3,183
I have my XP laptop that has Step 7 installed, it is the laptop I use that has a serial port & PC slot for my 5512 card. However, recently the...
2,271
Hi everybody, I search alot without any result. I have a machine operated by a Easy 512. My counter is already done, all working perfectly. My...
1,487
Hi, I have 0 experience with Modicons. A friend asked me if Im able to help him out with simple programming of Modicon 512/612 PLC. I believe...
1,759
Hello there from New Zealand. Needing help with the above named relay which is running my remote septic plant. Can only program directly to...
1,917
