6186-M17ALTR Versaview 1700 Touchscreen blankout
mvannantn
Jan 2003
bangalore
32
I have a 6186-M17ALTR allen bradley versaview . The touch screen is blankout and no displays and no back light anything. But the status LED is green.
Also I have found there is Back light enable and the 12 V supply is going to the PCB.
Does anyone know of something else i can try before buying a new unit?
Manivannan
Correct
Most likely the backlight bulb or inverter board is blown.
We fix these all the time.
If the inverter is gone a lot of the time the bulb is getting
black at the ends and will cause the inverter failure.
Hello, I am working on a project under Schneider M580, We have an existing supervision PC station develloped with Wonderware Intouch. The...
960
Hi all, I've got a facility that has multiple VersaViews across the floor. Every time I change the HMI, I've got to load it on each of them. Does...
699
I have a VersaView 1500P (6181-15TSXP Series E) that has a failed hard drive (2.5 inch SATA). I could get a new hard drive for it. Although, I...
1,488
Hello, I'm installing a Windows 7 on Versaview 1700P panel but I'm having troubles with the touch system, but I dont have drivers to resolve that...
1,348
Has anyone tried to update the windows XP on a AB Versaview/Panelview +CE. Or am I going to have to replace the whole unit. Our IT group is...
1,746
