700VDC Load Switch?
einnh
Mar 2014
New England
275
Anyone know of manufacturers that make 700VDC >=50A rated DC load switches? My pocket vendors/manufacturers don't seem to know of them.
Regards,
700VDC is tough because it's not an industry standard voltage. 500VDC, 600VDC, then 1000VDC are standards. Many devices are rated for 600VDC, but very very few are rated for 1000VDC, which is what you would have to use.
It's going to be VERY expensive too. What do you have that is using 700VDC, and where is it coming from? Generally on something like this, since the source is usually a rectifier fed by AC, it's easier/ cheaper / safer to disconnect the AC side.
If this is a solar PV application, I think that ABB and a French company called Socomec have 1000VDC rated solar PV disconnect devices. They are typically multi-pole devices and you run the DC through 2 or 3 poles in series to get the necessary air gap required to interrupt a DC arc.
Regards,
I use Gigavac contactors for general EV stuff, and I have read their spec sheets that list voltages above 700VDC. All of their stuff appears to be single pole single throw. The largest of the Gigavacs claims load-break in the >1000A range.
http://www.gigavac.com/catalog/power-products/gx-series
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
28
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
235
Hey guys, I have to take an upload of a program on an S71200 PLC to change a hardware config option and then redownload the program with this...
111
Please help me How to B&R 7CP476.60-1 upload program Backup and download which program should I use. Pvi transfer tool.? And how. Thank you
88
I HAVE A OLD MESSUNG HMI AND I WANT TO UPLOAD A PROGRAM FILE FROM IT TO A USB PENDRIVE WITHOUT USING PC OR SOFTWARE...WHAT SETTINGS I HAVE TO DO...
83
