755 Encoder question
Apr 2003
Toronto
151
I have a 755 Drive with a Single Incremental Encoder Module.
I want to have the drive running on one encoder channel (A).
I hooked all the wires up to my encoder and set the bits in word 1 such that BIT#1 is a 1 (A-Channel only) I also set Bit #4 as Single ended.
I ran the motor and my feedback error (PAR 641) Shows 52.456 RPM
On the encoder MMI i see no feedback on the MMI when the motor is running
Any one have a Flashlight and illuminate what I am doing wrong ??
Thank you
Some more Data that I found
The drive is set to EDGE counting on the original feedback, not sure if that implies A + B Up and Down the manual just states that if you want edge counting just insert a 1 into the bit pattern.
What I did was: I left the wiring as is (no removal of wiring) and changed the bit to look at channel A only it did work but the feedback speed has now increased. My Speed feedback error is now +/-0.000
I can only deduce that the increase in speed (almost x2) is due to the feedback channel B being ignored so the drive sees 1/2 of what it used to see. To make the speed loop happy it needs to double the output speed.
This is not what I want or need. Can I change the Encoder pulses per Revolution to 1/2 of what I have (1024) or do I need to re-calibrate the feedback ???
We have a PowerFlex 755 application using an incremental encoder for feedback. Is it possible to reset the Feedback Position to zero or a set...
2,284
Hello people I am having trouble resetting an incremental encoder in the PF755 drive. In the PF525 inverter I use parameter 560 and through...
1,752
Good morning, I have not had much luck getting a direct response from my distributor on this question. We have an existing chain conveyor system...
4,399
Hi everyone, I'm working with the powerflex755 that has an encoder card. I'm trying to read the encoder value in studio 5000 through "Traveled"...
3,242
Integrating PowerFlex 755, Incremental Encoder, & Proximity Sensors into Ladder Logic Hello All! This is my first post so please give my...
6,419
