Mordred,
I think that it is the same project. As you see, I asked many questions in that old thread. Chris apparently thinks that someone can write him a working program without knowing WHICH terminals his Inputs and Outputs are connected to. A program will work only as good as the information used to create it. Poor info = poor results. Who wants to risk his reputation writing something that is almost guaranteed not to work, simply because there is not enough info to do the job?
Here are more questions that Chris needs to answer:
1. Which of the six 5/03 processors are you using? (Choosing the wrong one will prevent your program from running!)
2. Which Input modules are you using? You said they were 16 Inputs, but are they the 1746-IA16, 1746-IB16, 1746-IC16, 1746-IH16, 1746-IM16, 1746-IN16, 1746-ITB16, 1746-ITV16, 1746-IV16, or you just don't know? Using the wrong one in a program will result in compile errors!
3. Which Output modules are you using? You said they were 16 Outputs, but are they the 1746-OA16, 1746-OB16, 1746-OB16E, 1746-OBP16, 1746-OG16, 1746-OV16, 1746-OVP16, 1746-OW16, or you just don't know? Using the wrong one in a program will result in compile errors!
4. Are the Input and Output cards installed? If so, which slots are they in? Which slot is the RTD card in, and what is its correct Part Number? Using the wrong module part numbers can cause the processor to go into Fault mode!
5. Is the PLC configured for the correct arrangement of the modules? Using the wrong slot numbers can cause the processor to go into Fault mode!
6. Is the SLC 5/03 already wired up? Is power connected? Are the inputs connected? Are the outputs connected? If so, where is each one connected? Using the wrong input and output addresses will cause your program not to work!
Answering these questions is a real chore. That is why it is usually easier for the Questioner to submit a preliminary program, with the processor, rack, slots, modules, and I/O configured to match his set-up.
