chrisflint
OP
Lancie1 said:Chris,
Take a look at this version. It only has 38 rungs, yet includes:
Other features you may need:
1. Decide if you need to reset the sequencer to Position 0 if the On/Off Selector Switch is turned off, forcing a sequence restart at Position 1, OR
2. If Selector Switch is turned off, should all valves close, and then restart at same place in the sequence when the switch is again turned on?
Hey Guys I am really impressed!!
This weekend i will load the code into my test plc here and check it all out.
I do like how the outputs are directly driven, i was using bits to read and write to because i didnt realise you could directly read the outputs, also i thought there was issues with double coils. Another issue i had was when you switch to stop, i didnt see how to de-energise the relay when it was operated direct from the sequencer.
Yes i do admit i do have lots to learn, thats why i am trying to get my company to place me on the AB 5 day course.
also i can see i would use soo much memory up on my code compared to yours, let alone all that time and excessive rungs.
Lancie1, there is one other feature that it needs (as you guessed) that is feature #2, when the run switch is switched off, the valves all need to close, then when switched back to run the sequence resumes from its last position.
I really do thank you for your time and efforts and will be studying to see exactly how the sequencer works so then i can give it a go writing some code myself.
Once again, i am really greatful, you are all a credit to the forum.
Regards Chris
