chris55555
Hello everyone!
We have an smt line with a conveyor that lost its program when the battery died. There are three conveyors in total, the 1st one, that lost the program was made in 1997 and the other two are from 1998. They have 90 Micros in them, IC693UDR005FP1 I am trying to pull the program off a running one to store it on the downed one. We do not have backups of the programs.
I have tried using a usb to serial converter with Proficy Machine 9.5 on a windows 10 computer, It was able to connect and upload the hardware configuration successfully, but when uploading the logic or forced values it comes up with the error: "Error 8097: Server Error - Transfer Error: Remote disconnect has occured [0x6A][0x02]"
I also tried LM90_9.05 on virtual box running winXp, using the db9 serial port on the computer, connected to a MOXA TCC-100I rs232 to rs422 converter and then through a custom cable to the plc. With this setup I can connect to the plc and get the configuration, but not the ladder logic or reference tables. LM90 says "<S43> communication failed" It seems like it drops comms when uploading the ladder logic, and after the <S43> error comes up, the communication starts again. I also tried this setup with the usb to serial converter, it also drops comms when uploading the ladder logic and comes back online after the error. The error is either the S43 comms failed or it says "Error during load; Program folder incomplete. Must reload or restore logic".
I seem to get these same results on each of the plc's.
also, theres no password, LM90 says I have level 4 access. And there was a fault in the downed PLC that I cleared: "PLC CPU software fault"
Any help or direction would be appreciated,
Thanks,
Chris.
Thanks,
Chris.
