Panelview 300 Micro upload issues
diat150
Mar 2006
Louisiana
1,475
I am trying to upload a program off of a panelview micro 300.... without much luck.
I am using a 1747 UIC, which I believe is necessary because from what I can tell, the unit is setup for DH485. The PLC(micrologix 1200) is setup to use DH485, baud 19,200, and node address 1. The panel communicates to the PLC, so I know the comm port is working.
I installed panelbuilder32 and when I try to upload using the UIC driver, It quickly throws the following errors:
error 2258 unable to communicate with operator terminal, did not receive a response
error 2258 verify your cable connections
info 2258 if you are using a direct connection to a panelview via df1, insure that the panelview does not have its printer port enabled.
I am kind of stuck here and was hoping that maybe someone could shed some light that has more experience with these.
PanelBuilder32 has a built-in direct DF1 driver, and can also communicate using RSLinx Classic.
Which method are you using ?
If you are using RSLinx Classic, does the PanelView 300 Micro show up in an RSWho browse ?
I am using the rslinx option. I figured I had to use this option since the panel was setup for DH485.
Yes, the panel does show up on a browse with rslinx.
wow, looks like I needed to use the rslinx network instead of the UIC option in the dropdown box in the upload menu. From there I was able to browse to the panel and click ok to start the upload. weird.
Is this the clock battery flat? Does anyone know how to remove the back of the PV 300 micro. Is it possible to replace this battery. AB says it's...
1,171
I have an opportunity to get some more experience replacing an old Panelview 300 Micro. I'd like to hear any advice you have about it. I suspect...
3,305
I lost the manual for this machine built in 2003 and need to put it back together. I have the Micrologix 1200 and PanelView 300 Micro programs...
1,784
I am tying to download application software to a fresh out of the box PV 300 Micro. The first hitch is a prompt that I am running v4.1xx RSLinx...
1,150
I went on a service call yesterday for a Micrologix 1500. An output wasn't activating and they wanted to know what was hanging it up. It was a...
2,816
