A-B CPU fault
Tim,
I assume that the run light is off? Do you have access to RSLogix programming software? If so, I don't have a book in front of me, but if you can go online with it, there is a diagnostic choice under one of the menus. I also seem to remember a S word that tells you why it failed. Start there. I think people here will be able to help you easier.
George
If you have logix 500 then go online as stated in the above post and drop down the box in the pic where my arrow is
It should say FAULTED in red
In there click Goto Error ( or fault, cant remember which) and it should tell you why the processor has faulted by bringing up status file S2
In there on the bottom right you will get a description as in my pic S6
edit: also try turning the keyswitch from RUN - PROG back to RUN if you havent got logix500 this may work on a non major error but you wont know what caused it witout going online
hello at work we have a machine controlled with an SLC 500 fixed, model 1747-l30c at fault, i plan to migrate to a micrologix controller. I'm...
3,025
Hello everyone, I got called down to a plant to service a powdered metal press. It has an SLC 500 5/02 CPU that was faulted for the code 0002h...
1,815
Hello intelligent people, I hope you guys can help me I currently have a problem with a telemecanique TSX 17 plc The plc was cut off power supply...
2,814
We bought a used SLC500 (1747-l40A) from a vendor. Comes with one year warranty. It's still on our test bench. I downloaded a program to it and...
21
4,218
Hello guys. CPU showed major fault indication.what could be reason. Kindly help and guide to solve the issue. Kind regards.
1,356
