A/B DH+ Comms problems
bks
Aug 2003
A/B 500-4 plc with DH+ comms comms lockup on plc if you remove DH+ plug from cpu DH+ LED remans on the only way to reinste the comms to power down plc I have check all the message blocks registarys over laps
can eny one help
That symptom sounds like the DH+ outgoing MSG buffer is full. How many MSG instructions are there in your program ? The SLC-5/04 can process four messages simultaneously, then there is a buffer that will hold ten more (they get the ".EW", Enabled and Waiting, bit set). If you overflow that buffer, though, the port gets jammed up and you need to cycle power to reset it.
In encourage you to proofread your next post. Your sloppy grammar discourages people from assisting you.
So, the background to this issue is yesterday this VFD got a cooling fan fault, every fan inside was working properly and was clean. We have no...
1,694
Hello, I have a problem and certainly just one of many to come as I become more involved with PLCs We've got a panelview 1000 connected to a SLC...
3,178
Good morning all, I'm having problems connecting to an AB L31. I'm using an Allen Bradley 1756CP3/A lead through a USB 232 converter. Software is...
2,345
Hi I'm trying to communicate with an SLC5/03 with a 1747-CP3 SER A RS232 cable. Even moved the jumper inside the module from protect to program...
1,731
I'm trying to get my S7-315 plc to communicate with my MP 377 HMI Station over ethernet but I'm having some problems. I have all the correct IP...
6,290
