RoTaTech
Equipment: SLC 5/03; PV600 DH485.
I was at a customer's site where the 5/03 power supply was not tightened into the chassis/backplane, and when an electrician tried to open the PS door, the CPU faulted. I could not go online, the program was corrupt.
(Any ideas about that one?)
Anyway, we eventually found the OEM CD and reloaded the ladder. But of course, all the customer's recipes/programs/setups - call them what you like - were history. They have no PC and no-one capable of going online to upload or download. They had 20+ recipes that had to manually re-entered, with no paper backup of the parameters. Likely took them a day or more to do.
So I told him that I would look into a permanent backup. I thought that I could turn on a bit and flash the ladder and data to EEPROM, then just do a Load from EEPROM on error or on startup.
Seems not. I only know how to write to the EEPROM from RSLogix, not from the ladder program. I recall reading about a programmer which could plug into the SLC and load the CPU (I will be searching for that as soon as I finish writing this). Can that unit do what I want - i.e. make an on-demand backup of the program (or at least specified data tables), and then reload it?
Another option - is there someway I could save that data into the PV600 onto the PC-Card?
Cheers in advance
Cheers in advance
