A block convert from S7-300 Simatic Manager to S7-1200 V16
tulip
Oct 2005
ist
236
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200 TIA Software. The program is below and records the operating hours in a DB when the relevant engine is activated. And this program is called 25 times.
Parameter entries:
IN0: Pulse input once per minute.
IN1: Engine started information.
IN2:(Relevant engine number in byte format, from 0 to 24 decimal value)
IN3:Data Block.
FC10:
OPN #IN3
L #IN2
L L#6
*D
SLD 3
T #TEMP4
ON #IN0
ON #IN1
JC M001
L #TEMP4
+ L#8
T #TEMP5
L DBB [#TEMP5]
+ B#16#1
T DBB [#TEMP5]
L B#16#3C
<I
JC M001
L B#16#0
T DBB [#TEMP5]
L #TEMP5
+ L#8
T #TEMP5
L DBD [#TEMP5]
+ L#1
T DBD [#TEMP5]
M001: AN DBX [#TEMP4]
JC M002
L 0
T DBW [#TEMP4]
L #TEMP4
+ L#16
T #TEMP5
L L#0
T DBD [#TEMP5]
M002: BE
Thanks in advance for any help..
Example code:
Code:
FUNCTION "fc1_Engine" : Void
{ S7_Optimized_Access := 'TRUE' }
VERSION : 0.1
   VAR_INPUT
      In0 : Bool;
      In1 : Bool;
      In2 : Byte;
      In3 : DB_ANY;
   END_VAR
   VAR_TEMP
      TEMP4 : Int;
      TEMP5 : Int;
      byData : Byte;
      bData : Bool;
      wData : Word;
      diData : DInt;
   END_VAR
BEGIN
    #TEMP4 := BYTE_TO_INT(#In2) * 6;
    IF NOT #In0 OR NOT #In1 THEN
        GOTO M001;
    END_IF;
        #TEMP5 := #TEMP4 + 1;
        #byData := PEEK_BYTE(dbNumber := #In3, area := b#16#84, byteOffset := #TEMP5);
        #byData := #byData + 1;
        POKE(dbNumber := #In3,
             area := b#16#84,
             byteOffset := #TEMP5,
             value := #byData);
        IF #byData < 60 THEN
            GOTO M001;
        END_IF;
        #byData := 0;
             area := b#16#84,
             value := #byData);
        #TEMP5 := #TEMP5 + 1;
        #diData := DWORD_TO_DINT(PEEK_DWORD(dbNumber := #In3, area := b#16#84, byteOffset := #TEMP5));
        #diData := #diData + 1;
             area := b#16#84,
             value := DINT_TO_DWORD(#diData));
    M001: #bData := PEEK_BOOL(area := b#16#84, dbNumber := #In3, byteOffset := #TEMP4, bitOffset := 0);
        IF NOT #bData THEN
            GOTO M002;
        END_IF;
            #wData := 0;
            POKE(area:=b#16#84,
                 dbNumber:=#In3,
                 byteOffset:=#TEMP4,
                 value:=#wData);
            #TEMP4 := #TEMP4 + 2;
            #diData := 0;
            POKE(area := b#16#84,
                 dbNumber := #In3,
    M002: RETURN;
END_FUNCTION
Helo I have a FB-Libary in Step 7 v5.4 i want to use in TIA-Portal V11 Sp2. How can i convert this?
5,159
How To Convert S5 Data Block To S7? When I Open The Data Block Of S5 Only..km Or Km Or Kh Or..format Allow Me To See. Regards
4,727
Is there anyway to take an RsLogix 5000 Ladder and auto convert it to Function Block, or any software that would automatically do it. even Ladder...
7,477
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
119
Hello, This product that I have the 1790D-T8BV8B is discontinued, does anyone have the EDS file for it? I wonder if TechConnect will have this...
188
