davidg68124
I guess the way I am understanding things is this, he has one of the analog outputs from the 1336 drive set up to retransmit the drive current back to the PLC. I was also understanding that he wanted some type of formula to use in the PV+ to convert that current to frequency. Unfortunately, that is not possible without more information coming from the drive.
On the other hand, if I understand RSDorin, if things are the other way around, and you are reading the commanded output to the drive from the SLC, ie, the speed reference to the drive, you can use the scaling of the tag in the PV+ to allow you to display the COMMANDED frequency. But that still is not the actual running frequency of the drive.
David
David
