AB 1400 micro on a Siemens TP177b HMI
Jeff23spl
Jan 2010
Canada
860
I had a customer that wants to read is AB micrologix data on a Siemens screen but we didn't succeed to make it works
Wincc flex 2008 with that terminal make availaible the AB df1 or 485 driver
The TP177b itself as only a 485/422 port
The micrologix can be either configured for DF1 or 485
but none of these configuration seems to work...Do someone have any idea or a clue to make it works ?
We did make works a TP170a with RS232 connection the same way on a Compactlogix few months ago...but TP170 are phase out now for tp177....
we added a 6AV6 671 8XE00 0AX0 rs422 485 cverter and it works very well
just the data and time format for access pointer became a headache but finally solved by individually isolated each part of the tima and date in separate words
Hi! Last few I've been trying to send message from MicroLogix 1400 to Micro 850. Unfortunately every time I failed :banghead:. Did someone tried...
3,212
Hello, There was a mix up in information on some redeployed equipment and two of the micro 1400's that came in were hooked to 120v when they...
1,963
I am trying to exchange data (N registers) to and from a Control Logix PLC. I am programming the messages in the Control Logix program, to...
2,189
Does the 1100 only have 1 high speed counter, but it can have multiple inputs? And so then the 1400 has 6 HSC and you have a choice of multiple...
1,723
Error: "Program in processor has changed causing offline state. Do you want to upload?" RSLogix500 V8.10 Micrologix 1400 Customer wants to add...
2,293
