Ab 1749-flex
mobil1syn
Dec 2018
socal
79
coworker randomly mentioned that you could get a flex card with built in disconnects. i cant seem to find anything indicating this, is he disillusion? got a large piece of process equipment built over multiple skids. i am laying it out so each skid will have its own JB with a remote I/O to simplify install. not having a bunch of terminal blocks in the JB would make my life simpler.
He' s probably referring to 1794-TBNFs; these are fused terminal bases to be used with 8-point Flex Output modules.
Also, the 1794-TBKD bases provide 16 knife switches for disconnecting the attached wiring.
You might call the TBNF fuse assemblies 'built-in' disconnects since releasing the fuse sockets will open the attached field wiring.
thank you, that is exactly what he was talking about.
Hi guys. I am interested in the possibility of a series of modules repair Allen Bradley SLC 500 In particular, the 1749-RTD and all analog input...
1,967
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
168
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
169
Hi, I'm currently having issued with a PowerFlex 252. It was working fine last week, and suddenly decided to stop working. When I go into...
120
Hello, I'm hoping someone can help me with understanding how to set/change these data types. We recently swapped from Invertek to AB drives...
102
