AB 1794 Flex I/O -Hardware help
ason
Oct 2005
Home
317
Hey i haven't work with AB so much so here i need some help please,
I have a PLC 5 with DeviceNet
Now i need to setup a new nod that im going to connect 3 encoder Lenord Bauer 293 for length measurement
http://www.lenord.de/en/produkte/sensorline/inkremental/gel293/TI293_e.pdf
It´s a UN type that is on page 2 in the PDF,
TTL 10-30VDC
I wonder which card i need for this encoder type?
I have been reading the manual for 1794-IP4
http://www.literature.rockwellautomation.com/idc/groups/literature/documents/um/1794-um016_-en-p.pdf
But i cant relay understand what they mean with N & D on page 2-13,14
Shouldn't i have A, /A, B, /B inputs?
Or do i need some other card?
And i need a Flex i/o communication module with devicenet, where to find manual and ordernumber for that?
I am not familiar with the 1794-IP4, but searching the word "encoder" in your linked manual yielded one result, and I saw no mention of any method to synchronize values between channels. In other words, I am not sure it will be possible to accurately use that card with a quadrature encoder signal.
I would recommend that you look into the 1794-VHSC.
I have not used it either, but I have used a variety of other HSC modules for encoder applications so I expect it's a better fit for your device.
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1794-um010_-en-p.pdf
Thanks alot!
I have take a fast look and it looks it´s this i need, what i understand it have 2 channels.
So i need 2 of those.
So now i need to find a Flex i/o communication module with devicenet,
Hi all, what is the proper way to fuse 1794-IE12 modules? fuse sizes/locations? We are burning up these modules in our facility.
1,737
Does anyone have any insite to when the 1794 Flex io will go active mature? Just not ready to switch to the new flex 5000. We use flex for remote...
1,626
Hey guys, Im currently using the above flex IO to turn on two outputs these outputs go to two flashing red beacon lights. Here's the scenario: My...
1,727
Anybody can help me. I already read document in software rslogix 5000 and I think i can use software rslogix 5000 calibrate for flex module...
1,746
This is going to be long winded just because i am going to try and provide as much info as possible. Over the last month i have had the...
2,427
