AB ControlLogix BSL or BSR Example
Coachman
Sep 2006
Maryland
97
Would anybody have an example of a BSR or BSL. I would like to set
up a shift register to check product on a turning device, so I
can activate another process. Could you also give me the purpose
of
Control:
Source Bit:
Thanks in advance
Rephrase Question Concerning ControlLogix -BSL
Good Afternoon ,
I am somewhat familier with the shift registers in the older AB plc's. Could you explain a couple of
things dealing with the BSL in ControlLogix. What an example of the Array , Control , Source Bit , Length.
Let me explain what I am doing. I have a part on a chain that I am looking for with a sensor ( input ).
This part of the chain that I am sensing the part is about 3 steps away from the process that I would like
to take place. For example, If I see the part at that position I would like for this seen part ( as a 1) step
thru to that position 100 , 010 , 001. I have 27 positions on this chain ( would that be the Length?)
BSL
Bit Shift Left
Array -
Control -
Source Bit -
Length-
Thanks in advance,
I am having trouble with a bit shift left instruction in RS 5000. It will not take my array tag. I was using register[0] for the first bit in an...
2,634
I have a turning device that has 27 shelves on it and I would like to keep track of the shelves that have product on , and then activate a process...
2,626
99
180
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
119
