NetNathan
Can someone open this file? If you have Studio 5000 version 20.05.
I can't open it in newest version 32.03.
Thats not the same thing. You will have to download 20.X to open a 20.X file. V32 will not work.
Each version (ignoring sub-version) is a unique program.
Do i need full version of 20.05, or can I load software option to V32 that will allow me to open an earlier version?
Would you risk installing V20 on same drive with V32? Sounds risky...probably a VM would be better choice?
I think @NetNathan meant the risk is a new install of v20 when v32 is already on the drive, because that act might break the v32 installation. For multiple versions, the common wisdom I have seen on this thread is to install older versions first.
No experience, just sayin'
I've personally never encountered any issues either having multiple installs on the same machine or installing revisions out of order, but I have seen several horror stories mentioned on here that I would still recommend following that advice
