AB-ControlLogix - MOV function in ladder and FB equivalent
Thanks OG.
I'd like to do the following with function block:
if condition is true
Update register A (Real) = register B (Real)
if condition is false
register A is available to accept user's input
Any suggestion is appreciated.
Thanks Ron,
I have Register_A is the interface tag to DCS, so when it is not used by the plc program (when condition is false), it needs to be able to accept user's input from DCS. Is there a way that Register_A can receive update data from another register within the plc without being tied to a specific block.
Thanks.
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
86
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
216
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
197
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
233
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
