AB controllogix serial Comm Barcode Data
rhasta
Jun 2009
sgpore
Hi, im new in AB contorllogix. may i know how to configure rslogix5k in order to get the string dumped by barcode reader? if i direct connect the serial Comm barcode to ControlLogix5555 serial comm, how should i configuration of MSG and its communication? thank you for viewing.:geek:
The only thing I've ever used a Logix controller serial port is for configuration purposes. I have never seen that port utilized for data...
2,687
Hi. Anybody know which Wonderware I/O-DA server I should use to communicate to AB ControlLogix via USB/serial cable. I am relearning Wonderware...
3,082
It Seems "ARD" Instruction hangs up sometimes after an "ACL" instruction executes. Processor: 1756-L55 / V16 firmware Program Steps: [ARD]...
5,739
Hello All, I am trying to talk to a serial device via Controllogix L5550 Serial Port. Reading thru the device manual, it appears the...
7,836
Hello All, I am trying to talk to a serial device via Controllogix L5550 Serial Port. Reading thru the device manual, it appears that...
2,727
