Alan Case
RS485 is the physical connection ie the cable. DH485 is the protocol, it is a proprietary AB protocol and as such is not compatible with other companies 232 to 485 converters.
Ken gave 3 really good methods to solve your problem.
Re-read his post and answer the question of how fast do you want your data and how much data do you want to send.
This will tell you what method to use. Once you decide on the method then if you are still having problems come back here with the method you decided on and I will try and help you.
You can get cards for the SLC that have DH485 ports, I was going to give you the model number but see my other post for the reason.
I dont think multiple DH485s this way are the go. Kens methods are more appropriate. Regards Alan Case
