Connecting Ethernet TCP/IP device to CompactLogix
Lobo12
Feb 2024
NC
I have a device that is currently connected to a UR 10 robot through a UR Cap and I would like to connect the device to an Allen Bradley CompactLogix 5069-L306ER PLC instead so I can use it with other robots (device only has a URCap at the moment). The device use Ethernet TCP/IP, I have the IP address of the device that was used to connect to the UR and its native protocol. For example, I know "Get_State" is 0x00 02 and "Register_Client" is 0x00 03 for info, and there's some others in the protocol. I am a noob when it comes to communication between devices so I apologize if this seems obvious. I have been trying to use the MSG instruction to send 0x00 02 to the device using CIP read and CIP generic but I think I am missing something as it wont let me put hex in as the source element on CIP read and I am lost on the custom settings for CIP Generic. Any help would be appreciated.
I have a device that is currently connected to a UR 10 robot through a UR Cap and I would like to connect the device to an Allen Bradley...
348
Hi All, I have to connect a slave (Digiforce 9311) to EtherNET/IP scanner (EL6652). The EDS file informations must be transfered into IO...
357
Hi I have two PLC AB compactlogix 1769-l16er-bb1b on the same location i need to read level sensor on the other PLC I know each one IP address...
1,300
I have a Micrologix 1400 to which Ive assigned a specific IP address. Now when I am trying to configure it in Rslinx, i cannot find it under...
37
10,467
First of all Hi, nice to met you all. I have a problems trying to control my PLC's (1762-L40BWA ser. C and 1763-L16DWD ser. B) with the Panelview...
5,058
