AB EthernetIP connections
DamianInRochester
Jan 2011
Rochester NY
1,292
Looking through the CompactLogix selection guide, I am looking at the specs and it is listing
as
"EtherNet/IP nodes in a single Logix
Designer application, max"
for a 1769-L24ER-QBFC1B
Can anyone give a more clear definition of what they mean by "nodes in a single Logix Designer application"?
Is the restriction only on nodes I setup in the IO tree on the left? Does that mean connections to my Laptop or to the PanelViewPlus are not counted? I had always treated this as total connections in the past.
I believe the reference is to how many remote I/O nodes you can have. Although offline it is letting me create 10 without any errors. Perhaps downloading to a live system would yield different results.
Your laptop and PanelView connections still count as TCP and EtherNet/IP connections, just not toward the node limit.
That's how I interpret it. Maybe someone else can chip in if they know differently.
OG
When I downloaded to a controller with more than the allowed limits it caused errors
Thanks Jeff and OG.
I am looking on page 314 of Rockwell Automation Publication 1769-UM021D-EN-P - December 2012
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1769-um021_-en-p.pdf
Table 49 is a bit confusing. On one hand it seems to imply 256 CIP and 120 TCP connections are OK, but then under Produced/Consumed tags it lisr 32 MultiCast and 128 Unicast tags max, with note (2) that these are the maximum number of CIP I/O connections. Looks like I am going to have to dig through the manuals to gain a better understanding, but it does appear that the limit of 8 is only in the setup of the IO tree.
Gents, We have a few AB L35E CPU's in our machines, and we have already some connections to the EthernetIP port of this CPU. These connections...
3,006
Hi There. I have PC to get few tags from PLC into C# windows forms application. What is the best and fastest way? I could not find Omron in...
317
Hi, I am experimenting with different devices & am battling the connection sizes. At present, have a 1734-AENT/C, 1xOB8 & 1xIB8 I have tried...
1,136
Hello All, I'm sorry that this will have been asked a thousand times, but I cannot find the specific question to search for. I am looking for...
843
Hello, I am looking for some information on converting a Flex IO (1794-ADN) which is device net to an Ethernet/Ip Flex IO module like an AENT...
436
