AB FBC Instruction
seadeeare
Jan 2012
Sparrows Point
I have successfully configured an FBC instruction to compare a reference and a current valve setup of 25 valves over a 9 step process. when the valves are not set correctly as per the reference for a particular step in the process i get a value in the result array(s). i would like to use this result to set the corresponding bit in a word allowing me to pass that status (valvesetincorrectly) to my SCADA system.
In one example the result array would have an entry of 17, indicating that valve 17 is set incorrectly for the particular step the process is in. i then want to use that value in the tag valvesetincorrectly.17 and set it to a 1.
Anyone have any ideas on this?
thanks
seadeeare
Check out this Instruction.
DDT
Description: Compare data against a known, good reference,
record any mismatches, and update the reference to match the source
Thanks for the reply
i did look at that instruction but i didn't want to modify the reference source. the FBC instruction works perfect but i was having a problem with moving the solution from the result array into usable information for a SCADA screen. decided to go back to basics and coded in RLL exclusive NOR logic to compare the input valve settings to the reference settings giving me an output when they match. therefore i get a good indicator when the source valve position matches the reference valve position be it opened or closed.
Thanks again for the reply
Aint nothing like the basics though
cdr
Logix 5000 v32 on 1769-L16ER I used the FBC instruction to scan an array of DINTs for true bits and it works but I found a thing that just...
93
Good afternoon all, I am attempting to get a panelview standard 1000e too communicate completely with a 1756-L83E through a 1756-DHRIO card and...
2,881
I have (2) L541 5/04 PLCs in the plant and up until 3 days ago they were fine. I replaced the battery in one of them and had to reload the...
1,931
Was wondering if anyone would know how long it would take for the processor to execute the FBC instruction with a length of 40 and in the all per...
2,493
In my SLC 504 programs, I have used the FBC instruction to scan a word for a bit that has been set. This instruction is not supported in the...
4,229
