AB flex I/O
jabski
Dec 2003
Hello, I have just had my flex I/O hardware delivered and have a PLC5/40 AB program on the PLC processor which needs to be tested. Being a student on vocation work i have little experience with PLC's (2 Weeks). The hardware includes 5 input modules and 6 output modules,two flex I/O adapters, and 11 terminal bases.
I need to know what has to be done to configure the inputs and outputs in my program to communicate to the correct ports of the hardware. There might be a lot more involved like the DIP switches in the adapters need to be touched nicely.
Having fun
Jabski.
Time to post some part numbers.
Probably you have two 1794-ASB Remote I/O adapters, and the Series letter is very important with the configuration of those modules. Make sure you know if you have a Series A, B, C, D, or E adapter.
Next post the precise part numbers of the FLEX modules you intend to attach to each adapter.
Basic discrete modules don't need much configuration; in fact, there's an "autoconfigure" function in RSLogix 5.
Analog or specialty modules need "block transfer" instructions in your ladder logic program to configure them and transfer data to and from them.
A-B manuals are available in PDF format for free at www.ab.com/manuals.
That's a good place to start by downloading the 1794-ASB manuals.
Part Numbers
Thanks Ken, i am planning to have two racks one with input (in series) and one with ouputs(in series). The part numbers are:
- two adapters 1794-ASB
- 5 input modules 1794 -IV16
- 4 output modules 1794 - 088EP
- 2 output modules 1794 - 0816P
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
186
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
172
Hi, I'm currently having issued with a PowerFlex 252. It was working fine last week, and suddenly decided to stop working. When I go into...
121
Hello, I'm hoping someone can help me with understanding how to set/change these data types. We recently swapped from Invertek to AB drives...
103
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
51
