pat@magnum
Program logic and Configuration are lost and PLC reverts back to as shipped state of INVALID CONFIG if PLC is powered down longer than approx 3 seconds. Tried 2 different PLCs, same result - swapped bateries same result - yes, autostart is enabled. I don't see anywhere where I can check battery. I assume there should be some time allowed for a battery swap even if the battery is bad. Did I miss something in the configuration ? Am I just lucky and have 2 bad units ? My local AB tech support has no experience with the GuardPLC - aint life grand.
