GuardPLC and Point I/O's over Ethernet IP
Switek
Nov 2008
Cork/Ireland
25
Hello,
I am struggling with getting 1734 Point I/O's working with GuardPLC 1600.
The 1734-AENT adapter connected to GPLC1600 via Ethernet has two 1734-OB8/C modules connected.
Connections to the modules are set as Direct exlusive owners.
I managed to download the scanlist configuration to the GPLC and the first module works fine, but the 2nd is not sending any data. Just receives some.
Connection status on the GPLC shows Established and then switches to Configure and back to establish.
RSNetworks shows Connection TimeOut to the 2nd I/O module and then Success...
I know that only one can be per assembly on GPLC, so I have two separate assemblies, however I do not really know and can not find it anywere, how to determine the assembly size and how those asseblies are refering to the scanner configuration in the GPLC.
The OB8 is not faulty, as I've replaced them on the slots and the 1st always was fine.
I've called Support, however they don't know even if that's possible.
I would be greatefull for any help and suggestions.
Regards,
Switek
Hi All, I am trying to create a new module to communicate with in my RSLogix program but it keeps failing and coming with "Error - couldn't...
1,353
How can I take multiple bits and put them in a word? I am trying to report status info to a SLC 5/05 via ethernet. I have a message in the SLC...
2,228
Hi I am new to this so please be patient, I have programmed ControlLogix before and now require to program a SIL3 GuardPLC. Firstly I would like...
2,199
Program logic and Configuration are lost and PLC reverts back to as shipped state of INVALID CONFIG if PLC is powered down longer than approx 3...
1,785
Has anyone managed to communicate to a Inview display from a GuardPlc. Even through a intermediatary PLC. The Inviews are on ethernet network and...
4,251
