Ab hsce2
Kevincrs1548
Jun 2013
Hamilon
Hi there ! I'm desperate for help. I'm trying to configure an SLC 5/03 with a HSCE2 module. I've tried to read the horrible AB manual , but I cant seem to get the 'count config' portion to initialize. Does anyone out there have a line or two of code that might point me in the right direction.it seems that the module initialization works, it just stops after that. I can see the pulses in the input table file ,they are just not what they should be.
The 1746-HSCE2 is in the top five trickiest SLC-500 modules to set up. The manual is OK as a reference if you already know the module well, but its deficiencies as a 'getting started' manual are well known.
That's why there are a truckload of RA Knowledgebase documents about the HSCE2 giving descriptions and samples of various simple configurations.
These include but are not limited to:
Knowledgebase Article 18721 (TechConnect Required): "1746-HSCE: As Simple As It Can Get".
Knowledgebase Article 18100 (TechConnect Required): "Minimum Configuration for 1746-HSCE: Class 1, Mode 1; Class 4 Mode 1."
Knowledgebase Article 16585 (TechConnect Required): "Getting Started with 1746-HSCE2 Module - Control Blocks".
Hi all I need your help, I have a 1746-HSCE2 card configured, the pulses read perfectly, but I have a problem as I use the pulse counters in...
2,181
Hi everyone. It's been a long time since I have asked for your help but I have been given a heap of plcs cards that have been changed out that...
1,215
I recently had to set up this module and would like to share what I learned, as this was a difficult process for me. The HSCE2 high speed...
2,117
I'm setting up the HSCE2 and just about have most everything coded and ready for testing. As anyone familiar with this card may know, the manual...
1,375
We have a fault with the existing HSCE card. I need to replace it with a new HSCE2 card. The processor is SLC5/03 Could some one please help me...
1,447
