AB IF2OF2 Question
gatfu
Jan 2013
kansas city
62
I am currently trying to hook up a 4-20 valworx actuator to an AB IF2OF2. The Valworx has 3 Pins for control/status. PIN 1 is the common (-). PIN 2 is the 4-20 IN (control). PIN 3 is the 4-20 OUT (status). The IF2OF2 shows the connections as (I out 0) and (Common) for the load control and (IN -0) and (IN +0) for status. That makes for a total of 4 connections to be made to the IF2OF2 however the actuator has only 3 connections. It only has one common out. My question is how do I go about hooking this up? I had planned on connecting PIN 1 to the (common) and Pin 2 to (I out 0). Then connect PIN 3 to (IN +0). Now what do I connect to (IN -0)? since they are sharing the same common at the actuator can I just jumper (IN -0) to the (Common) or will i fry it doing so?
Hey all, Been working on a little project using a Micrologic 1100, Just added this 2-in/2-out analog module (1762-If3Of2)to my project, and a...
2,200
Hi All, I have a question about the 1762 if2of2 analog module.When i connect both inputs with voltage option (dip switch on voltage position) i...
2,540
I have a Moog hydraulic servo valve that operates a cylinder that moves up and down. I have the 1762-if2of2 hooked up to it and sending the 4-20ma...
2,631
Hi Sirs, Good Day. I have a simple questions/clarification regarding the connection of "negative channel" and "com" of the analog input module...
1,729
I was trying to use a Micrologix 1100 and a 1762-if2of2 Analog IO card to demonstrate A/D and D/A conversion. Simple ladder logic Enter a value...
3,889
