AB Kinetix, changing scaling units
pulu256
Mar 2015
Chch
Hello,
first post here and first question.
I'm currently using a Kinetix 5500 drive, in Logix Designer I can set the scaling units and values.
What I need is to be able to switch from millimeters to inches and change the scaling value without having two or more different plc programs. Is it possible to do it using an instruction?
Thank you
Yes you can but why would you?
when my client needs this I use mm internally and have a scale divisor that = 1 if mm and 25.4mm if inches for all operator displays
I naturally use SI units and can set up all limits and understand the drive velocity and acceleration values in mm/s etc, if I was to use inch that would slow down my fault finding and commissioning.
If you do look want to change the scaling on the drive look at the GSV instruction
+1 for MichaelG's answer.
Stick to one set of units in your program, and then just scale them as appropriate for the user. That is easy to switch on the fly.
Does anyone know these drives that can help? I need to move a home position on a drive by -500mm. I've physically got the carrier in position, but...
1,749
Hi All, Is there a way to change, in the PLC code, the Homing Position parameter that is displayed in the Properties window of the Kinetix servo...
3,636
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
99
Dear team, We are constantly facing M07 incremental loss on one of our kinetix 6500 safe torque. We have changed Servo motor (MPL-B4530K-MJ72AA)...
114
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
151
